苹果Mac系统下安装完SUAPP跳出提示怎么解决?
在mac book pro上安装完suapp,su没有显示插件(plugins),并且跳出对话框,内容如下。求大侠指导。
载入文件 /Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suapp_main.rb 时出错
Error: #<LoadError: dlopen(/Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suruby/lib/i386-mswin32/rgloader.darwin.bundle, 9): Symbol not found: _ruby_current_node
Referenced from: /Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suruby/lib/i386-mswin32/rgloader.darwin.bundle
Expected in: flat namespace
- /Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suruby/lib/i386-mswin32/rgloader.darwin.bundle>
/Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in `require'
/Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suruby/lib/suapp.rb:4:in `<top (required)>'
/Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp/suapp_main.rb:7:in `<top (required)>'
/Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp_loader.rb:3:in `require'
/Users/vincent/Library/Application Support/SketchUp 2014/SketchUp/Plugins/suapp_loader.rb:3:in `<top (required)>'
请安装SUAPP2.5以上的最新版本,支持最新的SketchUp2014,老版本不兼容2014,SUAPP有专门的MAC系统程序安装包,请下载时留意。安装过程可以参考以下链接中的动画教程:http://www.suapp.me/tutorial_75.html
如有疑问请在下方添加评论。
